Doesnt want to climb hills any more, need help (please)
If its only acting up in one direction than its not usually a belt issue.
Sometimes guys will over adjust the shift lever to make it go a little faster and doing so can sacrifice some reverse pressure.
I'd make sure the shift lever is properly centered as described in the manual on page 24 and 25.
Some units also have issue with water contamination if stored outdoors make sure the fluid is not milky, contaminated, or even low.
Thanks for the link, will take a look at the fluid, tractor does stay outside. Putting new belt on tomorrow
To me replacing the belt is a give me as it is a primary wear item like blades.
I found a big chunk missing from my deck belt last year, and replaced it. I couldn't believe how much further I had to move the tensioner pulley to get that new belt on. With the old belt, when I hit the PTO, it would squall a bit at first. With the new belt... nothing. So I agree, belts are wear items.
So - did you ever install a brand-new belt? If so, was it the same size or 1/2 inch smaller?
Installed a new belt and that was the problem, surprised more experts didn't suggest it
Sometimes it takes a retired industrial R&D chemist/former air-cooled VW mechanic to tackle a simple issue.
As a belt wears and slips, it glazes and won't grab as well. I have a 2005 Craftsman LT1000 I use to cut weeds such as tumbleweeds in a small town, and I always have a supply of new belts, blades, spindles, pulleys on hand....and I only use Kevlar belts.
