In troubleshooting a popping issue I discovered that the electrical connection to the fuel cutoff solenoid was lose. When I wiggle the connector (doesn't take much) I can hear the solenoid cut in and out. I had a spare one from another carburetor that fit the connector better but it has a plastic plunger at the end instead of brass. The other solenoid came from a different VTwin with a single barrel carb. The (factory) part number for both solenoids are the same. The replacement OEM part is almost $200. I was wondering if anyone had a similar issue and/or if they would use a plastic tipped solenoid? If not, do they have a source (part number) for a cheaper solenoid with the better connector with a metal (brass) tip?
