I got a Craftsman 917.370600 mower and all of the wheels are angled but the mounts are solid. They're easy enough to adjust, but the angle remains. I only took the time to remove the wheels to inspect, clean & lube- the spindles are angled but not bent. What's the best way to make them straight (or ar they angled to make replacement necessary sooner than normal?)?
The photo shows this-
This mower was treated like a farm animal- when I got it, grass was on it, in it, under it and because they probably left it outside, water ate the deck at one of the engione's mounting bolt locations, so they put a washer on the bolt, which did no good, whatsoever. I think someone hit a big tree root because three of the five lobes on the blade adapter were sheared off and if the steel was already compromised, it caused the hole. Sorry about the photo orientation- they open normally in the software.
Thanks
Thanks
