I have a Bolens 13AM 762 f 765 38" 15.5 HP tractor. Turn the key and nothing not a click or anything. I have already jumped the starter from the battery which made tne starter crank. Thje battery is good. New solenoid and ignition switch. I did find a red wire with a black stripe with a sta kon on the end of it hooked up to nothing. It is not long enough to reach any connector that I can see. It is positioned below the seat in the tranny tunnel and I can trace it to the ignition switch. I have had the seat safety switch disconnected for 15 years which were 2 yellow and black striped wires. I did hook it up to the solenoid battery side but still nothing. I am most likely going to use this tractor for hauling my dumpcart in the woods which means I will probaly take the cutting deck off since I have a new mower. If all else fails is there a way to bypass all the safety crap just to haul the trailer.
I would definetly appreciate any help I can get. Thanks,
Rosario
Rosario
