Riding Mower advise
ctdave
I am now 76 years old and I no longer want to mow my ~1/2 acre lawn - with my current push mower. What brand/ model riding mower would you recommend. I do want a reliable unit, price less of a concern. Any cutting width will likely suffice
My 80 year old dad mowed his 4+ acre "lawn" for many years with a John Deere 60 (??) inch cut riding mower - clearly a leading mfgr choice
Thanks for any advice!! -dave
For a lawn that small a 42" mower will be big enough. You will have to consider any gates that you may need to get through.
This Ariens unit would be a perfect fit.
I have the same size lawn and am the same age as you. Never really needed a rider but have had several that were either gifted to me or bought for chump change. These include 2 John Deeres, a Troybilt, a Craftsman, and 2 rear engine 28 inch Snappers. One thing I have learned along the way is that riding mowers require a lot more maintenance than any walk behind. They simply have more moving parts and anything that moves will eventually wear out. Belts break, pulleys wear out or their bearings fail. Spindles fail. Decks rot out. Transmissions fail or in the case of the Snappers need to be adjusted. Springs break or fall off. Cables stretch or break. Seats get torn. Safety switches fail. Tires dry rot or just wear out. So, whatever you get be prepared to get your hands dirty or pay someone to fix the machine. You don’t need a big deck for your medium size lawn so I would advise sticking with a single cylinder engine. They use less gas and are simpler than 2 cylinder engines. Smaller decks fit through gates better and take less storage space, so don’t buy bigger than you need. Hands down the most robust of the bunch I have owned are the Snappers. Unfortunately, they stopped making rear engine Snappers so if you want one, you’ll need to find a used one. These mowers are the Model T’s of mowers. Nothing fancy but they are rugged and do a good job mowing and bagging grass/leaves, and they shift gears on the fly. Any of the Briggs flatheads are good but in my experience the 8 HP model has all the power you need. So, my advice is to find a used Snapper and either renovate it yourself or get one with a healthy engine, seat, and deck that has had all the wear components recently renewed, ie: good tires, newish clutch disc, good spindle and belt. Hope you have lots of years ahead, but chances are you’ll be done mowing before the Snapper is.
I'll 2nd the recommendation for a Snapper RER. Even that will be overkill for 1/2 acre. Oddjob is right that riders require more maintenance, but RER's are the lowest maintenance option of the riders. Tractor-style (LT's, GT's, etc) riders are next. Zero turns are the highest maintenance. I'm not your age, but I'm close. I pushed mowers for decades, but I totally understand the desire to ride while mowing. My last move was to a property where my mowing needs increased about 4X, so now I have two riders. One big one that my wife uses on the bulk of the lawn, and a smaller one I use for trim work. For 1/2 acre, a Snapper RER is the right tool. That's if you only to mow grass with it. If you want to do other stuff, like tow a cart, trailer, aerator, spreader, etc, then a tractor style mower would be better.
Whatever you do, only consider a zero-turn rider. A 42" deck will do you nicely.
Not one 0-turn is as reliable as the world standard Snapper RER. One can find an "OLDER" clean 33" RER for $300-$600 around here.
Guy only has a half acre probably with the house and garage on that. So less than a half to actually cut.
Gentleman is 76 now. Working on some 2500lb over priced 0-turn I bet is not in his vocabulary. Most people don't have space to store a huge machine indoors. Left outside it will rot away.
This, IMO, is a bit of an exaggeration. My ZTR is an entry level commercial/prosumer model (CC Pro Z100), and it weighs in right at 1000lbs dry. 2500lbs is more like my utility tractor. The point is valid, though. The OP doesn't need a big heavy ZTR for 1/2 acre.
This IS one of the advantages of RERs. Most, if not all, of them can be stored pointed straight up, sitting on their tail. Takes up not much more floor space than a push mower.
The Ariens Edge 34 weighs 445 pounds.
I linked to it because of the deck size and other attributes.
I agree that a good used or refurbished Snapper RER is a good choice. Most of them will have a 28", 30", and 33" deck.
A self-propelled mower will also do fine. However, there seems to be a lot of people with walking issues and laziness in my experience.
