pugaltitude
Big hammer, bench grinder, and a smooth shaft, boy you sure got a different idea then I do as to what is smooth. If it was my job and needed a bench grinder it would be going to the recycle pile and get a new shaft. If the shaft is that bad turn it in a metal lath if you want to save it. Everyone has there own way of doing things. Sounds to me you can do the job over in about a years time because you are doing very poor workman ship.
A lathe just to get a lip off a shaft, its a lawnmower not a spaceship.
」50 for a new shaft or a bit of time to grind or file then use emery to finish it off.
I know which is the quick and easier way. :wink:
