Tecumseh carburettor gasket kits
Tbob86
I have 2 4 stroke lawnmowers with Tecumseh engines. Both have good compression but the carbys need overhauling. I am looking for kits for both. The mowers are circa 1980s or 90s. Unfortunately I don't know the model of the carbys but, have attached pictures. I would really appreciate any assistance I can get. Regards Bob Thomson
That is the vector vlv carb Really need the actual model and spec number to confirm which bowl kit that carb used. some used bowls with different colored emulsion tubes.
Further research shows it could be the 730637A bowl kit
Thanks. The number on one of the carbys is 1600D6F. I don't know if that helps. The 2 mowers have really served me well for many years and it would be a shame to discard them simply for the sake of one gasket. I can make all the gaskets myself, except for the one separating the float chamber and the body of the carby.
The emulsion tube on this carby is green.
The 500032C uses the 632675B bowl assembly The 500023B doesn't appear to be a correct number so may want to recheck that number.
Those style carbs were never really designed to be disassembled and rebuild, Designed to be a remove and swap the bowl assembly without removing the carb body from the mower.
Okay thanks. So is the 632675B bowl assembly still available and if so, who should I contact. Regards Bob Thomson
My Tecumseh distributor doesn't show any in stock, but doesn't show them as NLA either. Found a couple on Amazon that appear to be OEM for what looks like a decent price.
