22hp B&G engine governor
Dsawyer44
The governor quit on my 22hp Intek engine. I looked online to see how to replace the governor gear. The articles i read show a flat washer under the governor gear. The articles show a flat washer with a 90 degree tab on them but mine just has a washer with no 90 degree tab. Is this normal for a 22hp intek engine model 441777? Thanks.
Here is a picture of the typical washer under the governor gear used on your style engine, and the one I tend to see.
It would help to have the spec number that follows the engine model number.
Here's the one they show on EBAY and also on you tube. Thanks for the help. I'm enclosing a picture of mine.IMG_0900.JPGIMG_0900.JPG
The tab goes down to prevent it from rotating with the governor spinning. Not all had the tab, but they do the same job.
