I was hoping someone could help with some info. on the steering geometry for my 2013 X304. I got looking to see why there was so much play in the steering wheel, as the last owner told me that the rack and pinion was new last year. I was hoping to be able to draw the rack housing closer to take up some of the play. I centered the wheels to see if the rack and pinion had been centered when they were replaced, and noticed that the leading edge of the front wheels were really toed out. Is this supposed to be like this? I don't want to 'correct' it if it's supposed to be like this. With a straight edge against the rear tire, and the wheels centered to the machine, there is roughly 3/4" toe out on the leading edge of the front tires.
Also, something off this topic, I noticed the gas tank leaking on my X300 (2008). Does anyone know the best 2 part epoxy that's gas impervious to fix the hole?
Any information on either question would be massively appreciated. TIA.
