I use one of the jigs sold on Amazon, and other sites as well, that holds the blade and a 4 1/2" angle grinder at a preset angle to sharpen my blades. I use 40 grit flapper discs. I love it, it's fast, and does a good job. I touch the blade tips up on the grinding wheel to get it correct and then balance. Problem is, the flapper discs don't last. They seem to get polished, and then won't hardly grind. Is that because of using it on hardened steel ? Is there a way to revive the disc, or is the problem bargain discs off Amazon ?
