Hello all.
First the stats you ask for.
Weedeater push mower pull start basic budget homeowner mower.
Briggs and Stratton 80000 450E engine.
Owned 8 years.
Symptom: Press prime bulb a few times. Engine roars to life after a few pulls. About 20 seconds later it quits.
When I prime the engine. Does it let in air or gas.
Using True Fuel 4 cycle gas exclusively.
What I have done to resolve the problem:
Replaced carb with new carb. Replaced sparkplug. Replaced gas. Put Seafoam in tank. Replaced fuel cap with OE fuel cap. Bale switch is clean.
Today I will pull the gas tank, check for blockage. Is there a filter in there and do I need a filter? I will try to check the magneto with a multimeter.
In 2021 I replaced the magneto (weak), carburator, bale cable.
Any help would be greatly appreciated.
Owned 8 years.
