This engine is on a 1984 Snapper RER. I have not been able to get it to smooth out. I have cleaned the carb very thoroughly and replaced the gasket. I have recently adjusted the valve clearances. It starts easily. But it runs like a hit and miss engine. I just put in a Chinese clone carburetor and the miss disappeared, BUT it ran way too fast. My tach recorded 4900 rpm and was slowly climbing. I tried adjusting the high speed screw but could not get it to slow down, so I shut it down. I checked the governor arm and it was properly adjusted. I put the old carb back on and the miss returned but the tach showed 3200 rpm. Did I get a defective carb? Can a carb make an engine overspeed? I thought the governor would prevent overspeeding. Could I have a bad governor? Why would it govern speed with one carb but not the other? I have cleaned a lot of carburetors but I can’t help but think I’ve missed something on this one. Is there a passage on this carb that is hard to see?
