I have a Dewalt Pressure Washer (DS3532) with a Subaru EX270D503618590 Engine with a Mikuni Carburetor (Foam type) that was surging so I disassembled the carburetor and cleaned it. After I reinstalled the carburetor it was still surging so I did some more research (this forum is great with a wealth of information!) and looked at youtube videos. I have two questions:
* The main jet (correct term??) in the tube that is normally unscrewed to remove the jet and then able to clean the tiny holes on the side appears to be pressed into place and cannot be removed. I have not been able to find out if this tube should be removed to clean further, or not. Any thoughts?
* The pilot jet I removed and cleaned the side & top holes but I could not tell if there should be a tiny hole at the bottom of the pilot jet to clean. If there is supposed to be a tiny hole here mine is clogged and I have soaked it in a sonic cleaner but still not able to find a hole. Any thoughts?
Pictures are below and hopefully this will help more than my misidentifications!
Thanks again for your help!
Paul
Paul
