2003 Cub Cadet model 7254
Big Bobby
I’ve got a 2003 CubCadet model 7254 posi trax tractor trying to find the electri clutch for the front and rear pto engagement have 12.7 volts to plug going to clutch inside of rear end any help would be appreciated thanks
It is not going to look like a lawn mower PTO clutch and it is in the PTO drive gear box. Hard to tell from the IPL but the service manual says it in the transaxle assy. Service manual doesn't its resistance reading but should probably be 1.5 - 5 ohms if similar to lawn mower PTO clutch readings.
Supposedly NLA since April 2016.
thanks for the reply i have been looking for one of the clutches since 2024 ive even checked over seas found one in germany but i would have to buy the whole rear end $35.000 plus shipping
Hey BB, 1st disconnect plug at pto and put 12 volts to plug going into trans, should hear click. If no click check for good ground with test light. I found broken wires at pto clutch on 2 tractors. You will need to drain fluid from gear box, remove seat top trans cover, you will see the wires at pto, not a easy job but after repairing wire harness at the pto they have both been fixed. If not repairable trans will need to come apart. This came be done by removing fluid, top and rear trans covers. remove other parts as needed. Not a really hard job if you put removed parts in order.
