- Feb 19, 2020
- Threads
- 119
- 12,777
232A is not used on your type no.Alright, I want to thank you guys for the information you supplied. As far as I can tell, it has only one spring which is missing In the attached carb breakdown # 232A, but it doesn't show where to attach the spring. I also feel that there should be some sort of spring near the bottom of the tank where the linkage runs down to near the bottom of the engine block. I'm definitely not a small engine repair guy. attached is the schematic showing a spring near the top. In the picture of the tank I think a spring needs to be at the bottom somewhere but not sure.
That lower spring is the governor spring. Without the engine only idles.
PN has not been superseded
The long loop end goes to the governor arm.
