l008com
- May 25, 2015
- 337
Last Fall, I was winterising my equipment and I accidentally stripped the spark plug hole on my yard vacuum. Its a 31 year old machine and I didn't turn that hard, so its probably a failure that has been inching its way to happening for a while.
But no worries, this is a great opportunity for me to make a video about repairing stripped spark plug holes with helicoil type repairs. I used one of those to fix the brake rotor mount on my mountain bike and it worked great.
So the question is, does anyone have any specific suggestions for a specific kit (with links) that is good and that has everything you need in one kit. Including the drill bit UNLESS its a standard size bit. But I don't think it it, its probably bigger than 1/2" right? So the bit, the coil, the install tool, the thread tap etc.
I know I could also repair this by just replacing the head. But I'm making a video out of it so I really want to use a repair kit rather than a replacement head.
