ferris z2 blades stuck on
Auto Doc's
If you unplug it and check resistance and get no reading the windings are open in the PTO clutch. You will need a new clutch assembly.
lukewuko
I didnt test on the pto I tested the wires going to it and they have no power with the switch on I was getting power earlier when the blades were stuck on i could still her it click with the switch and now im not getting any power
Auto Doc's
Hello L.,
That is uncommon, but not unheard of. Check for power with a test light, but also verify the grounds are good.
Do you have to be in the seat for the safety switch to operate? Is the brake set?
lukewuko
Hello L.,
Oh wait I might be an idiot. Ill get back to this sunday.
