ferris z2 blades stuck on
lukewuko
2017 Ferris srs z2 61" 28hp vanguard blades won't disengage. I've tried a new pto switch and that didn't fix the issue. I'm just looking for any input on what i could try to fix the problem. Thank you!
Auto Doc's
Can you unplug the PTO wires, and the blades still stay engaged? If so, it likely has a seized-up/ failed PTO bearing.
Auto Doc's
AD, You mean a PTO seized/stuck in the on position.
Hello G.,
It is not very common, but I have seen this happen especially where high humidity is a factor.
Also, on rare occasion I have also remove an electric PTO clutch and it basically fell apart in my hands.
lukewuko
So I found out I had a stuck bearing I fixed that now I cant get the blades to engage I checked the fuses what should I look for now?
Auto Doc's
Hello L.,
If you have a multimeter, Ohm the 2-pins going to the clutch with it disconnected from the chassis harness.
If you don't get a resistance reading, the magnet windings are likely burnt.
Is the air gap adjustable on that clutch design?
lukewuko
Hello L.,
I dont believe the gaps adjustable I tried the wires going to the clutch and theres nothing there so I guess im going to trace wires or change the control module
