Karcher G2500VH Pressure Washer Help
AgentDoug
I know this is a lawn mower repair forum, but I figured I would try my luck. I bought a used Karcher G2500VH pressure washer with no water pump. Using a caliper, I found that the shaft from the Honda GCV 160 engine is exactly 20mm (a hair over 3/4"). I haven't been able to find this water pump anywhere. There are loads of 3/4" shaft water pumps out there, but I can't seem to find a 20mm version.
Any help or advice would be appreciated.
Are you sure it is 20mm and not 7/8". Everything I find says a 7/8 shaft.
Now Honda Honda GCV 160 comes with three possible shaft PTO ends 22mm, 22.2mm(7/8"), and 25.4 (1"). Now LM series does have a 20mm x 26mm tip then goes to 22mm the rest of the pto length.
LM PTO drawing
N1 PTO Drawing
N5 PTO Drawing
AgentDoug
LM PTO drawing
N1 PTO Drawing
N5 PTO Drawing
I'm sure the shaft is 20mm. Also, it uses a square, 4-hole bolt pattern. The 7/8" pumps I've seen use a triangular, 3-hole bolt pattern.
Auto Doc's
Have you looked into Predator engines? They are a Chinese clone of the Honda engines in most cases.
Auto Doc the OP is looking for a pump not an engine.
I'm sure the shaft is 20mm. Also, it uses a square, 4-hole bolt pattern. The 7/8" pumps I've seen use a triangular, 3-hole bolt pattern.7
Well there are four point mount pumps in the 7/8 line up.
But if you post the engine model and spec alpha numeric codes. Then we probably find what the PTO dimensions are and what will fit it.
