Stihl FS 55R weed Wacker
johnorlandi
Hi Guys
I have a Stihl FS55 R weed Wacker that I am using a lot of gas. I used to do the entire yard on a full tank of gas but now it is taking a tank and a half. I re-adjusted the carb and put in a new air filter, the plug looks good, and the spark arrestor is clean. Gas is mixed correct. Any ideas?
Auto Doc's
Hello John,
Have you looked down into the plug hole to check the cylinder for scoring? You can also remove the muffler to actually see if the side of the piston is scored.
Are you using the correct number spark plug it calls for and not just one that fits?
Are you using a different 2-stroke oil in your mix?
Is the string head spinning freely like it should, or is it tight from gear binding due to lack of lubrication?
Otherwise, it sounds like the engine is getting tired and losing compression with age and use. Maybe a small about of extra oil in your mix will help
Tiger Small Engine
Hi Guys
Possible fuel leak?
When was the last time the metering diaphragm and inlet needle been replaced? And also is the metering lever height set at the correct height?
johnorlandi
Hello John,
johnorlandi
Thank you for responding Auto Doc
Plug = I had a E3.12 that was about .030 and replaced it with a new auto lite gaped at .020
Cylinder = I removed the muffler and the wall looked really good and from the plug hole it looked good also, a little wet carbon on the top of the piston but really good.
Oil = I use Stihl 5.2 oz to 2 gallons of gas
String head = I grease this a couple of times a year, so it moves freely.
Did a compression test and had trouble reading the gauge when pulling the starter rope but it looked like 60 psi or more.
Let's see if the plug change does anything and if not, I will try what Star Tech says about the carb. It won't be for about a week or so before I use the weed Wacker but I will let you know
Thanks again
johnorlandi
Star Tech. Thank You
I Have not been into the carb for a real long time, but I will keep that in mind. See my response to Auto Doc
Thanks again
johnorlandi
Not sure I will keep check. I do not see any gas around but I will take a better look the next time I run
Thank You
First you must obtain a proper small engine compression tester as a schrader valve [valve core] at the end of the hose. It will hold the compression reading after testing until it is released. Now these schrader valves are different than the ones used in tire valve stems as they a lighter spring in them.
Second this is a two cycle engine and it must have at least 100 psi compression to even start. If your reading is below this then either the compression ring is stuck or there is heavy cylinder and piston damage. First check for cylinder and piston damage by removing the muffler and looking thru the exhaust port as you cycle the engine; unless, you have an endoscope with a right angle mirror attachment. zrbf
Now Stihl units do carbon up over time due richer air/fuel so you might decarbonizing the engine using a decarbonizing fluid. Stihl dealers are suppose to carry this but around here none does. So I use some AC Delco version from the local auto parts store.
To do this you bring the piston to near top of the stroke where the exhaust port is blocked. Fill via the plug hole with the fluid and install the plug then you let the engine sit several hours. Remove the plug the spin forcing out any remaining. Then you attempt to start the engine. It will poorly at first as it burns off carbon and as it burn up the fluid that will be in the crankcase. If it was carbon stuck ring then the compression should start to improve after the first decarbonizing cycle.
