Ok. As you have 2 cylinders, you have to do each one separately.You will need a .005 feeler gauge.Remove both spark plugs. Remove both valve covers. Remove the plastic top shroud so you can turn the flywheel by hand.Take a screw driver that is fairly long and put it in the first spark plug hole and with watching the valves rotate the engine with your hand. You will see the rocker arm push on the valves. So there are 4 strokes to an engine, which is intake, compression, power and exhaust. You want that cylinder to be between the compression and power stroke. So you will see the top valve push down, and the piston will be moving down, the the piston will start to move up, and the intake valve will close. Bring the piston to the top, and just rotate it enough that it just starts to go down. Take your feeler gauge and it should slide in between the valve and the rocker arm. If it doesn’t, loosen off the 10mm nut , while holding the 14mm rocker nut. Rotate the 14mm one just slightly counter clockwise and tighten the 10mm lock nut. Do this until the feeler gauge slides in. Do the second side. Once you have done this, put the valve covers back on, the sparks plugs back in, and for safety, I’m supposed to say put the shroud back on. But what I do is make sure that nothing is around the flywheel (wires etc) and I will test run it to make sure the valves are not clacking. If the engine sounds perfect, I put the shroud back on. Email me direct at
dvata@yahoo.com if you need further help
