Honest Abe
- Jan 18, 2013
- Threads
- 3
- 299
if the blades are not level that can cause air flow disruption and weird cutting issues - Google can be your friend too.....This thread isn't about leveling the deck. Not sure how that has become a focus. The only reference to 'level' previously was about front-to-back tilt where someone suggested there shouldn't be any.
A "lawn mohawk" is typically caused by improper mowing, such as dull blades, uneven mower decks, mowing too fast, or excessive grass length. The blades are either torn, bent over by the mower's wheels, or laid down by the previous cut and not lifted into the cutting path, resulting in a strip of uncut or partially cut grass. Maintenance issues like a dirty mower deck or uneven tire pressure can also contribute to an uneven cut.
Mower-Related Causes
- Dull or Damaged Blades:
Dull blades tear grass instead of cleanly cutting it, and damaged blades can lead to an inconsistent cut.
- Uneven Mower Deck:
A mower deck that isn't level or has a caked-on underside can result in grass of varying heights.
- Mowing Too Fast:
Speed can prevent the blades from having enough time to cut the grass properly, causing it to bend over instead of being cut.
- Uneven Tire Pressure:
Underinflated tires on the mower can lead to an uneven cut.
- Overgrown Grass:
If the grass is allowed to grow too tall between mowings, the mower can struggle to cut it evenly.
- Mowing Too Low:
Cutting too much grass off at once can lead to scalping and unevenness.
- Improper Mower Turns:
How you turn the mower can create an uneven cut or a line where the wheels haven't properly cut the grass.
- Uneven Ground:
High and low patches in your lawn can make it difficult for the mower to cut at a consistent height.
