Timecutter Z5030 won’t move
pastorbud
I just bought a time cutter Z5030 on Facebook marketplace. The guy demonstrated it for me before I picked it up. He drove it forwards, backwards, in a circle, line it up with the ramps and drove it onto the trailer just fine. Now I’m home and when I started up, it won’t move forward or backwards when I push the levers. I used the drive releases to put it in neutral and roll it off the trailer, but other than that, I didn’t change anything. Both releases are back in the forward position now. Just acts like it’s stuck in neutral.
call the guy who sold it to you and ask what you are doing differently. Download a copy of the manual and read it.
Hi there. I have a Time Cutter also. The only thing I can suggest, make sure your pulling both levers to the center before you attempt to go forward or backward. & also check your Speed adjustment. Take the speed adjustment off of turtle setting. . I live in Michigan.
