Help on Maverick hydro gear
dibarber
I went out to the barn and Hydro fluid was under my mower. 60" Maverick k. I think a 2021 model. Anyway...jacked it up...there's a plug missing out of the side. I looked at the other side...it looks like a black plastic plug belongs in there. What do i need to buy? To replace it. Thank you.
Really need the model number off the transaxle to be sure but if yours is the 2021 model it should be Hydro Gear seal PN 55177 that for the internal brake shaft. Easy to replace.
Post the transaxle model number its serial number tag and I can look it up on the HG dealer portal.
dibarber
Well it's a 2020 model....I measured the diameter of the hole...it looks like 7/8 inch.
dibarber
7 / 8 = .875
1 / 4 = .250
dibarber
You sir are awesome...do you have one? I need it overnighted.
