- Dec 7, 2022
- 2,237
Lapping valves also increases the compression. When valves and the seats are pitted and carboned up, it really affects the engine performance.Lapping just makes the seat and valve shiney.
I don’t have a valve grinder, and surprisingly, most people don’t. Most people don’t even know what valves do, much less how to lap them. When a valve moves by turning with your fingers while under spring tension, that is what lapping helps prevent. When a valve leaks when you put gas on the cylinder head to test, that is what lapping helps prevent. Nobody said lapping valves was perfect. I believe you can buy a new set of valves for a bit less than a valve grinding machine.Lapping does not increase compression. Will not remove pits, not used for removing carbon, and has zero effect on performance. There are tons of marketing ads pushing this crap and it's all a lie.
The only value of lapping is to verify correct contact location of the seat on the valve and the width of the contact after the seat stones and valve grinder have done their work. That's it. Everything else is bull****.
But then you still have the seat...I don’t have a valve grinder, and surprisingly, most people don’t. Most people don’t even know what valves do, much less how to lap them. When a valve moves by turning with your fingers while under spring tension, that is what lapping helps prevent. When a valve leaks when you put gas on the cylinder head to test, that is what lapping helps prevent. Nobody said lapping valves was perfect. I believe you can buy a new set of valves for a bit less than a valve grinding machine.
You are convinced that lapping valves does no good? Then why has it been an industry standard since the first valve engines came into production? Can the whole industry be wrong?Lapping does not increase compression. Will not remove pits, not used for removing carbon, and has zero effect on performance. There are tons of marketing ads pushing this crap and it's all a lie.
Not the whole industry....just the gullible part of the industry. Let's take Permatex 80037 as an example. This material is your silicon carbide in 4 mixed grits... 120, 150, 180, and 220. Ostensibly the grit size decreases as the paste is ground between the face and the seat...or so Permatex says. Where does that reduced grit go? Some embeds into the face of the valve and seat because it is way harder than the metal you're trying to remove. That would introduce annular rings in the seat and face because it's grinding, not polishing. You want to polish you better go to 2400 as a minimum. Most of your so-called "lapping" pastes aren't .You are convinced that lapping valves does no good? Then why has it been an industry standard since the first valve engines came into production? Can the whole industry be wrong?
Why is silicon carbide lapping compound used if it does not work?
Whatever.These are mower engines not the space shuttle. Lapping seals valves to valve seats. Pretty important in the combustion process.
I don’t even know of a machinist in our area that will grind valves. When you factor in your time back and forth, and paying labor cost, it would be on the expensive side. Even new valves need to be lapped in to the old seats.These are mower engines not the space shuttle. Lapping seals valves to valve seats. Pretty important in the combustion process.
Either have to lap the new valves into the seats or have a seat cutter set like the neway. I have the Neway seat cutter and valve face cutters, but I probably wouldn't if it hadn't been required dealer tool for either Kohler or Tecumseh. I don't remember whch.I don’t even know of a machinist in our area that will grind valves. When you factor in your time back and forth, and paying labor cost, it would be on the expensive side. Even new valves need to be lapped in to the old seats.
