YTH 24V54 Trans axle mounting brackets
Backroads
2020 YTH24V54 has any one have problems with broken or split trans axle mounting brackets. All 4 brackets are broken or split.
If you are seeing cracks at the axle mounting flanges on the frame that normally means that the front transaxle support has either broken, broken the bolts off in the front of the tranny, or they have just fell out.
2muchgrass2mow
2muchgrass2mow
Had exactly the same thing happen with a Husky YT42DXLS, twice! Must be a Husky weakness. See my post July 9, 2022. I now have a JD X-370 and love it. It was pricey, but worth it. I loved the Husky too, for its automatic all -wheel drive, but couldn't abide the tranny actually falling out on the ground🙄! Get rid of it is my advice. It will likely keep happening.
