422707-121401 sump gasket
Step back and look before you break it.
Most likely another fastener. If you beat on it or use knives with force you will find out why AFTER IT'S WARPED OR BROKEN.
If you see any bolt heads in the deep holes they need to come out also.
Got it i found the fastener
Thanks
Check this out:
Ok here is where I'm at!
No change!
Opened engine and Governor is fine everything inside good so new gasket fixed small leak so I'm in better shape there!
I had a new carb and put it on adjusted governor and no change engine racing so I'm still stumped or doing something wrong all linkages the same!
Engine fires right up but no control of throttle!
I can only choke to get it to slow down but that's not going to work!
I have not found a video on tuning one of these engines unless I'm missing something!
Have you actually looked at the carburetor throttle plate? I have seen them come off and get trapped in the intake port before. That is all that is left.
Plate is fine
Could it Be sucking air someplace??
Would that cause it to run WOT?
Is the governor link hooked to the throttle? An engine cannot run wide open with a closed throttle. Are you sure the governor adjustment is correct?
The governor holds the throttle plate wide open i thought and will pull it closed as motor runs??
Govenor adjustment is a basic setting and pretty hard to get it wrong
Only one way to do it!
If its wrong nothing moves??
Anyway I have adjusted the governor many times to see if it changes anything
Nope
The engine speed is controlled by a balancing act between the governor and the governor spring. When the engine is running the governor should pull the carburetor closed, when you start the engine is there any force opposing the sparing? Trying to close the throttle?
Can you hold the governor linkage to idle and does the engine idle down? If so the governor is not working or the wrong spring is on the governor arm.
How are you adjusting the governor (or syching it to the carb)? With the control wide open, the carburetor should be wide open. Note which way the governor shaft turns to open the then throttle. Turn the shaft that direction as far as it will go, now tighten the pinch bolt Governor is now adjusted. Try to move the linkage to idle if it does not move you turned the shaft the wrong way. The linkage should move freely with no rough spots or hang ups.
NOTES. Aproperly adjusted governor should not cause surging. A lean mixture will cause surging. A carburetor cleaning may be needed.
If after properly adjusting the carb and even moving the linkage to idle does not controll the engine speed check the carbfor a loose throttle plate or a broken throttle shaft, or even the control lever loose on the shaft.
When the engine shuts off the governor naturally stops functioning and the arm will pulled to wide open by the spring, on starting the governor starts "working" and overcomes the spring closing the throttle plate to maintain set speed.
