Craftsman Edger Model #247.772460 (also, 25B-554D099)
hgoodwiniii
  • / Craftsman Edger Model #247.772460 (also, 25B-554D099)
Hi everyone, I'm a new member. Thanks for the add.
I have a craftsman edger (#247.772460) with Briggs & Stratton engine #10T802 0711 B1. I am able to start it after putting a new carburetor diaphragm and gasket.
My problem is that it won't stay running and stalls out. I can get it to stay running if I manually move the throttle shaft but as soon as I release it.
The throttle shaft is getting no action from the linkage and does not move when the engine is running even though everything is connected. It only moves if I move it manually.
Any ideas on this? Is this some kind of electrically driven throttle? Is there a throttle adjustment somewhere?
Thanks.
hgoodwiniii
I will go back and double check to make sure. Thanks for the link.
hgoodwiniii
Did you install the pump diaphragm and gasket in the proper order? Plus tighten the screws in the proper sequence? Section 3, page 9 of this manual will help you. http://www.tuks.nl/WFCProject/img/E...210-Briggs-Stratton-Service-Manual-L-Head.pdf
I went confirmed the pump diaphragm are installed the proper order. I am still having the same problem where the throttle is getting no action from the linkage and if I move the throttle the engine stays cranked if not it stalls.
I been searching around and seems that I am missing a spring that connects to the throttle shaft and to a brace the engine. The Briggs and Stratton part # looks to be 698719.
I'm thinking that may be my problem. Anyone have a picture of this spring on this engine #10T802 0711 B1? Thanks.
Auto Doc's
You might contact Jack's small engine and talk to them to see if they can find you a used one.
