new carb and no dirt or restriction as I replaced all lines from the tank and filter with fuel flowing freely. It appears to hiccup or fart occasionally, but not backfire. Full choke runs the best but runs at a higher RPM, Compression gage read 90 psi in about 4 revolutions.Can it fail, sure.
Needing full choke to run is a dirty carb and or lack of fuel delivery. Possible fuel tank vent failure.
Was this an OEM carb or a Chinese Scamazon/Fleabay clone?new carb and no dirt or restriction as I replaced all lines from the tank and filter with fuel flowing freely.
