Fuel filter micron rating
TonyPrin
I'm about to change the fuel filter on my Cub Cadet mower with a Kohler XT 725 engine. I'm finding fuel filters with micron ratings from 15 to 75. What micron rating should I look for?
Auto Doc's
The Briggs and Stratton 695666 is a very good one rated at 30 Micron.
Skippydiesel
If the engine manufacturer does not specify, I would suggest a filter micron anywhere from 50-120. My feeling would be one more towards the 100
Reasons:
  • The engines fuel delivery system will be able to handle a certain particle size without damage or blocking. No point in filtering out these particles.
  • Too small a micron leads to more rapid blocking of the filter = more frequent changes = more cost for no discernible benefit.
Personally I preferer the "plastic' transparent body/casing, gauze media filters. These are almost indestructible, allow for inspection without removal, the gauze media will not breakdown/deteriorate, can be cleaned using compressed air but better to replace . Good examples are made by Baldwin & Hengst (be careful to select original manufacturer1749515590523.png1749515811775.png);
MParr
Is this a single cylinder Kohler engine? If so, it's a gravity fed unit. If you put too small of a micron rated filter on it, it will not run.
Scrubcadet10
Moderator
Staff member
if its a XT775, there is a filter in the tank
Scrubcadet10
Moderator
Staff member
The OP isn't giving us a full description. He said XT725 and not KT725.
and an XT725 doesn't exist. So its either KT725 Vtwin or XT775 push mower engine
Auto Doc's
Not surprising.
Many people on this site ask for help and automatically think we are standing right there looking at their machine.
