Cub Cadet Engines
SeniorCitizen
Cub Cadet IntelliPower 42 in. Gas Riding Lawn Mower, Cub Cadet Engine, Hydrostatic Transmission​
Has anyone had experience with this engine
Auto Doc's
Nope.
Just have not read any good about them yet.
I'm waiting for the GPS and yard plot mapping models to come out, that way I can watch the mower do the work on my smart phone.
Scrubcadet10
Moderator
Staff member
I haven't really heard much about them... Taryl has a good video on the IntelliPower system.
Tiger Small Engine
They are usually Chinese knockoffs of Honda such as Lifan or Powermore. Dealer orders them this way to lower price point.
The engine are base on MTD's P90 engine with electronics added to carburetor where they are controlling the fuel mixture via sensors. They are basically using fuel management electronics which will give us a lots of problems to figure without an engine service manual. Actually I do have X90 with carburetor and fuel injection service manual from 2023 here and it doesn't even cover the new electronic controlled carburetor which has stepper motors in it. So this yet another item that got to be updated.
Update the manual actual does cover the new carb I over looked that section. And I was wrong on what stepper motor were controlling. They control the choke and throttle vanes and not the fuel mixtures. Thank to MTD tech support for pointing this out.
Auto Doc's
From what I gathered by watching Taryll's video, there is no way to refit these engines with a regular carburetor because they have no internal governor. Everything is controlled by electric stepper motors, a temp sensor and an RPM sensor.
I think someone at Cub Cadet division forgot to tell the upper management that these are still mowers that have to operate in extreme conditions. Kind of like why do they put a cup holder on a rider? Dirt, dust and clippings will attract to any sweating beverage container around the general area. (This had to be an office idiot and a crafty salesperson dream).
At the moment, I just do not see a future of any kind for this design.
It makes me wonder what happens if someone eventually attempts to install a totally different (conventional) engine, it will certainly mean a wiring harness and operator cables at a minimum.
Tiger Small Engine
I acquired a Cub Cadet XT1 with a blown Chonda from my neighbor. It had a broken connecting rod and a hole in the block. Her son in law changed the oil and said to her, “you don’t want to over tighten the oil filter” when he changed the oil. Needless to say, the oil all leaked out and pooched the engine.
I have attempted to repower this mower with a Kohler CV15S. It requires a throttle cable that has to be modified in dash. A muffler that has to be modified to install. Wiring that has to be hard wired (this is where I am stuck). I can get it to start, but not turn off, or charge battery. I believe it has a diode and no regulator/rectifier. Any help on wiring would be greatly appreciated. I have looked at wiring diagram and it is very basic, but still can’t figure it out.
Tiger Small Engine
I have attempted to repower this mower with a Kohler CV15S. It requires a throttle cable that has to be modified in dash. A muffler that has to be modified to install. Wiring that has to be hard wired (this is where I am stuck). I can get it to start, but not turn off, or charge battery. I believe it has a diode (no regulator/rectifier). The mower only has 60 hours on the chassis. Any help with wiring would be greatly appreciated.
