Craftsman T240 starting issue
Status
Not open for further replies.
Dcarter
Craftsman T240 has new battery and all connections are clean and tight. The only way to start the mower is to jump it with a jump starter. Any thoughts or things i should check or is this a problem with the mower. Once it is jumped, runs great. Started about a month after purchase. Thanks
Charge and load test battery. How many cold cranking amps is one month old battery?
I just wish OPs would post the real model numbers from the serial number tags. Using T 240 (CMXGRAM1130044) (13APA1ZT093) for research.
Having to guess at this having a Kohler KT725 engine. IF so when was the last time the valves were adjusted. It be that the ACR is not working due excessive rocker clearances. It takes a lot of extra amps when it not working to crank the engine.
Mower is a month old. Valves should not need to be adjusted at this age.
Status
