Need to Purchase Air Hose End But Where
Lowes has them. Tractor Supply Has them, Even amazon sell them.
Just about every hard ware store carrys them. I must have a dozzen in the basement just laying around.
If your bike tire is a little low on pressure and you don't have a compressor or air tank ( with air ) a hose can be made to steal a small amount of air from your wife's car tires , spare included , then she can have air replaced at her favorite tire repair shop or dealer .
I can have 4 Tundra tires aired at the dealer in less than 5 minutes and never leave the seat . I've never ask for the spare pressure checked but i suspect they would .
I don't care much for clamp connections for hose so this is what i do .
Place the hose beside the barb end and mark on the hose , with a felt tip , where each depression of the barbs are . That's where my very small zip ties are placed . I don't have fancy tools so i tighten the zips with pliers . Heat the hose with hot water to make it supple .
I don't care much for clamp connections so this is what i do .
Place the hose beside the barb end and mark on the hose , with a felt tip , where each depression of the barbs are . That's where my very small zip ties are placed . I don't have fancy tools so i tighten the zips with pliers . Cut off zip end . Heat the hose with hot water to make it supple .
