Tiger Small Engine
- Dec 7, 2022
- Threads
- 3
- 1,644
Two strokes are louder, and smoke. Those are probably the two main reasons that many manufacturers have gotten away from them a lot.Two strokes generally get a bad rap because of oil type and oil mixing issues. A quality air cooled two stroke oil is necessary and the ratio is important as well. As background I've flown two stroke powered Ultralight aircraft for over 30 years. The Rotax guys that didn't have oil injection always thought that more oil in the mix was better.....all they did was shorten the time between overhauls, coke up the top of the pistons, fill the exhaust port with carbon, foul the plugs and lock the rings in place. I went with a 100:1 mix for all my engines, not just UL but trimmers, chain saws, blowers, etc., and the plugs all looked like four stroke engines and never needed to be replaced. Rings stayed free, crosshatch was very visible after 800 hours and no decarbonizing was ever needed. The amount of oil is vanishingly small because of the roller and needle bearings in modern two strokes. If this were a really old plain bearing engine you'd need way more oil in the mix than 100:1 could provide.The brand of 100:1 oil is not important as long as it has a good name behind it. The other advantage in my case was full instrumentation for EGT and CHT. Two strokes do not like getting a too lean mixture. In your case it's simply learning to listen to the engine as you screw in the high speed needle to hear it break over from a four stroke to a two stroke. It's a learned skill that isn't magic, just a practiced ear.
Do not mix oil to fuel at anything except 50:1. You can do your research. You can argue. You can disagree. 50:1 is what is recommended.
If taken care of, two stroke equipment will last many years, especially if it is quality brand to start with.
