If the engine will not start, or runs very poorly, try this.
Tornadoman
  • / If the engine will not start, or runs very poorly, try this.
I see questions about starting all the time. Here is a mystery that had me baffled. The B&S engine on our rider was not starting. It had fuel, spark, compression. Everything an engine is supposed to have to run. I was dumbfounded. I removed the cover from the top just to have a look. As I was closely examining it I noticed the cutouts for the flywheel key and crankshaft did not line up. So I pulled the flywheel off, and surprise! The flywheel key had sheared. New key, and the trusty old B&S is still running ten years later.
platefire
You must have smacked something pretty hard o_O
Tiger Small Engine
Rarely does the flywheel key shear. I mean almost never.
Diwali
A few years back I had a similar issue with my B & S on a lawn tractor. The key was distorted (not sheared) in the keyway causing backfiring. It baffled me for a while until I read a post on here. A quick check and a YouTube video soon had it resolved. It’s amazing how much these forums help an ordinary bloke like me!
Tornadoman
Yes, strange malfunctions can cause a lot of consternation! Are you Australian?
How about
1.air
2.fuel
3.compression
4.spark, at the correct time.
