RZT Maintenance Parts
BT2 Zeke
I have a 2007 CC 50" RZT with a Kawasaki engine. I was looking the other day to start purchasing my spring maintenance items. I change the plugs, oil and air filter every spring. I do it so often because here in SE Texas it gets a lot of run hours put on it every year.
What I've noticed that given the age of the mower it's getting harder to find the correct oil and air filters. Am I imagining this or are any of you out there having this same issue?
TIA
Howdy neighbor,
Kawasaki has superceded a oil filter number recently, but I believe it's for the larger commercial engines, So it may be a different part number but will work on your engine and other kawasaki products.
What model Kawasaki is on your RZT?
If you're in the north Houston area I can point you to 2 good kawasaki dealers I deal with.
TIA
Dont know what oil filter you have but I crossed referenced to fram and got one at a fraction of the cost.
