Gord Baker
- Aug 21, 2018
- Threads
- 1
- 455
Please STUDY the Manual if you have one. Drain the Float bowl if you are able carefully replace it marking the Orientation if you do. Some bowls have an obvious drain. Snowblowers do not have air filters. Studies have shown there is no dust during snow events. Drain ALL the fuel out of the tank, a Turkey Baster works if you do not have a syphon. Re use it in a vehicle or properly dispose of it.Can someone tell me, how does this thing run when there's no obvious air filter?
Even though the machine is about 5 yrs old, it's like brand new. I was the first user, and have only put about 4 hrs on it over the past 3 yrs. When we got some snow last month, I could not get it to start. I did run it last summer just to check it out for the up coming season. While troubleshooting the problem, I could not locate any air filter.
I can get it to fire/start, by removing the spark plug, shooting quick burst of starting fluid into the head. The spark plug has good fire, had put fresh gas in.
Just puzzled, as this defies what I was thinking there should be some way for this engine to get air to the carb. I've looked at the schematics, and can not locate one.
Put 1/4 tank of Fresh Fuel in tank, Remove Spark plug and replace with new one. Then turn Fuel valve ON if you have one. Set to Full Choke and press Primer Valve 3 times. Be ready to back off the choke when it fires first Pull. Do NOT continue to try with Full Choke.
