Re install / Rear shock on a Ferris Zero turn
Ezvalet
Good afternoon
Can someone tell me - how to reinstall a rear shock on a Ferris. It needs to be compressed a bit to get the bolt holes to line up. Thanks in advance.
hlw49
Could you bolt the shock to the frame and them lift the body to line the holes up. Never tried just a thought.
Hammermechanicman
Wrap a ratchet strap around it to compress it.
Hammermechanicman
Yes i have. Many automotive gas filled shocks come compressed with a plastic strap you cut off after install. The ratchet strap achieves the same thing.
