Bearing for RedMax EBZ 7500
Richie F
I know RedMax is now Husqvarna and now makes RedMax backpack blowers.
I need 2 crankshaft bearings for EBZ 7500 (p/n 521521301)
These bearing are back ordered so would like to know of the bearing numbers stamped into the OEM bearing.
I don't have my blower apart to check and see myself right now.
I can then possibly cross reference the number to a major bearing company.
Or if I could have dimensions of it I would buy a shielded bearing and remove the shields to make it unshielded.
Yes parts are getting back ordered is getting ridiculous. I just order a muffler for a Husqvarna ZTR it is on back order at least 2 months.
Don't have the bearing in hand here either but here is an image of the bearing from Amazon. I not found a cross for those numbers yet. If you do post them and I add it to the file here.
Richie F
I'll try to enlarge it to get a better view of those numbers.
see if this helps. X16/16
Here is some service info that should help. Note the snap may not be present on the EBZ7500. And note the EBZ75 series is mention in the newer SM.
That number doesn't help.
Called SKF and asked them and they said nothing comes up.
I know that what I getting from several vendors too. Looks like you are going to need to pull the bearing and mic it yourself. Fairly it is just a standard Metric bearing. I even tried looking up the superseded PNs. The bearing numbers are probably to just there throw us off. It won't be the first time they did something like this.
Richie F
My order is coming and one bearing is in the shipment.
I'll measure it and maybe there is a number on it.
Richie F
Got one bearing from Jack's Small Engines.
The bearing I have is a NTN (Japan)
The number on it is 6302C
SKF has it listed
Timken has it listed as 6302-2S, the shields can be removed.
I'm sure there are other companies or places that sell this bearing.
Dimensions are:
Diameter 42mm
Inside diameter 15mm
Width 13mm
Hopes this helps someone.
