LawnDawg43
- Sep 27, 2011
- 14
I am trying to repair the engine on a mower of my father's. He purchased an old Snapper Comet second hand with an engine that is a bit of a 'hybrid' in that the builder used parts from various engines to complete this one. Not a problem since so much is common from engine to engine on these but I have no idea of the correct engine number, type, code, etc.
From one usage to the next the engine simply would not start. I have done the normal service, replaced the fuel hose, cleaned out the tank, and checked the ground on the ignition. When I held the exposed ground wire close to the engine cowling and pulled the cord I got a spark but when I reattached the wire to ground it, the engine does not seem to fire.
It turns over fine, the compression seems good and I have determined it is getting fuel as there is gasoline in the carburetor. It does have an older carb. design in that there is an adjustment screw under the bowl and a short adjustment lever/handle to the right of the carb. if you are facing that side of the engine.
I love figuring this stuff out but I am at a bit of a dead end. Any suggestions?
