john deere 757 ztrak
ACF
had this jd ztrak 25 hp 60 inch deck running,and stopping several times to test safety switches , stopped engine went to restart does nothing, the pto will engage could i have a start relay have gone bad. any cooments will be helpful
thank you
ACF
thanks jump across soleniod and sounded like starter did not engage could this be problem
finally completed the wiring checks found not broken wires and all safety switches are working properly, got it to turn over, but have a new problem when the key switch gets to the run position the engine try's to start vice waiting till it gets to the start position on the key switch and the starter solenoid continues to push starter shaft up onto the flywheel
any ssuggestion would be great
ac
Kenbu
Could you have the start and run wires on the key switch shorted or reversed? If the wiring is OK, then you may need a new key switch.
Ken
Tiger Small Engine
ac
New key switch.
ACF
owner tells me that he had to replace 2 starters and had the key switch replaced, not sure if key is oem or aftermarket
ACF
replaced key switch still wanted to start in the run position what now lol
Then there a wiring problem. Voltage is being applied to K1 Relay when ignition switch is put in run position. The S2 terminal of the ignition only has voltage on it in the start position. So it sounds like S2 and A terminals wires are switched around. Easily done when you not paying attention or don't know what you are doing when the terminals are remove the connector housing.
This should be the pin out for the switch.
EDIT> Adding Make/Break table
Off / Run / Start
ACF
here is a drawing of the john deere factory key switch pin arrangement and the wire color of each wire in them, only have 12 volts on red wire which is the battery, the data for the pins can off of the switch it self that was punched into thee pins as you tell 2 are on not labeled
thanks for the help you guys are great
