This Mule has always run rich and carbon fouls plugs. It’s getting to where it will need rebuilding or replacing. Is there a replacement Walbro carburetor available for this Mule?
That’s what I was thinking. I’m going to try a few more things in the morning. I’m going to recheck the choke cable adjustment. I’m going to pull the cover off of the mixture screw and see if I can fine tune it. If that fails, I will put a rebuild kit in it and smaller jet. I was hoping there was a Walbro replacement.Might be simpler to rebuild the carburetor and install a leaner jet.
You have a choice of 99, 102, 105, and 109 that leaner than the 112 that supposedly was factory jet.
Or order a new carburetor and leaner jet.
Might be trial and error on which one to use.
I already have. It hasn’t helped.put a BPR4ES spark plug in it. I've worked on several 600 series mules that fouled plugs, went up to BPR4ES from the stockc 6ES and that usuallys fixes them.
Right, the #112 is the stock jet.View attachment 69765
Jet for high altitude get smaller as altitude is increased. Note jet sizes are in hundredth of a millimeter. And they are usually marked.
Pretty bad. It’s done it for a while now. I’m going to tweak it a little and adjust the choke cable as described in the service manual.What is the jet size for high altitudes? I see no mention for an HA main jet.
Make sure the needle/seat holds at 7psi.
Carb float level?
How bad is the fouling? Pictures please.
