Intake valve. The maximum travel out is 3 cm rocker arm
Intake valve travel comes up to 2 cm. Mark
Exhaust valve when it goes inside. It's at the 1. 2 CM Mark
Exhaust valve all the way out. It's at the 2.3 cm. Mark
Okay these are just raw notes. The way I'm measuring is I go to the cylinder head and I make the origin for measuring distance. The plate that contains the bolt for the rocker arm so that is exactly 0 in
So then I rotate the flywheel and I come up with how far does the rocker arm travel as measured from the rocker arm and the tappet so I'm measuring that side.
If there's any confusion on the way I did this, please ask. Thank you
