mikeeee372
- Aug 17, 2017
- 22
Or is it held on a different way?I cannot remove the pulley because there is some sort of snap ring I think holding it on the shaft. See picture. Any help very much appreciated!
2000 Dixie Chopper xw2500 trans pulley.
You are right! Don’t have ace/ox torch so I elected to cut it off. Found a new pulley and ordered it. Will let u know how it goes. Thanks for the info.Can't be using a propane torch; unless, it is boosted by O2. What you really need is an ACE/OX torch to produce heat quickly the enlarge the pulley before enlarging the shaft.
