PTO Clutch Locked out
rajthepilot
Thank that link I get the info on my system updated to supersede 5218-134 to 5218-221. I will also bookmark that website of Warner, just why they don't link it is not known.
I also didn't have website in the vendor's file here but do now.
Thank you for the research. I was unable to follow how you went from Part # 5105090YP to a Warner PTO 5218-221. So does it mean, Warner PTO just makes replacement PTOs at a cheaper price than the original equipment manufacturer?
I did notice at some sites (https://powermowersales.com/ferris-5105090) that had 5105090 and 5218-134 side by side.
So should I go ahead and purchase this https://www.warnerptodirect.com/shop/pto-clutches/5218-221 and give it to them at the repair shop.
Warner is the original equipment. It is just that Briggs/Snapper purchase them from Warner and then mark them up.
rajthepilot
Wow, what a big mark up. Warner PTO 5218-134 is priced at $159.89, while Part # 5105090YP from Briggs & Stratton dealer is around $430. Thank you for you help. The mower is currently at the shop, but I will certainly do the voltage test or request them to do it as well.
Just two more questions. Can you please explain how you were able to find that the 5218-134 is compatible with 5105090YP, and also you mentioned earlier that you'd be installing Xtreme X0216. So is Xtreme another PTO manufacturer as well? Thanks
Lets start with this diagram for the answer to your first question https://www.partstree.com/models/s-...ton/engine-pto-group-s-n-2017681136-below-34/
Scroll down to item 14A in the list on the right and it shows Warner 5218-134.
Second Xtreme is an aftermarket PTO clutch manufacturer that many consider the top of the line PTO clutches due to upgraded electric coils, replaceable bearings, and the machined pulley
rajthepilot
rajthepilot
Thank you so much for your help. I've ordered (https://www.warnerptodirect.com/shop/pto-clutches/5218-221). I'll have the repair shop put it on and then let's see if it breaks down quickly or not. Hopefully not. They had to pry off the last one, it wouldn't come off. I had tried taking it off myself at home, but I was unable to.
Make sure they use antiseize compound on the crankshaft when they install the new clutch.
