Lt145h38dbv 84329
slimshady69
I shut my mower off went to restart it now it won't turn over at all. Battery is fine, I have power to the starter. I think it might be the ignition switch but not sure. (Update): changed the battery solenoid and positive wire,and that wasn't it, so I took my battery charger hooked it up to the starter so i could mow lawn, anyhow now the safety switch on the seat works. So I pushed the clutch or brake whatever u want to call it, and it usually lets me get off the mower with out shutting off but it shuts off, by the way my mower is hydro drive, I'm thinking it might be the pedal switch but not sure.
slimshady69
Brake pedal depressed and the pto turned off. And in some cases being on the seat or some mowers require the transmission to be in neutral if a gear drive.
Yeah I know all that still won't turn over
Bertrrr
Hop 12 volts to the small terminal on the solenoid ,if it kicks into start, the solenoid is good but you have a bad switch or connection
If the anti-after fire solenoid on the carburetor does not click when the ignition is turned on, check the fuse; unless, someone has removed it.
