Ryobi RM480E 38" riding mower won't move!
For information, I replaced my driving controller because the Ryobi one died just after 260 hrs in my case. I put a generic 3000 watts controller because in my case cost way less 3 to 4 times less and time will tell me if it will be more reliable? The bad, little more complicated to replace the original controller because you need to figure out the new connections needed. Especially the few info I found for Ryobi connection, my mower look like don't have the same color for wire.... The good, I just tryed and it work near as it was before with original Ryobi one, exception made, take care when backing, now I have full power and speed while backing. Another thing, now to get working mower, I must press The reverse enable red light to have working mower. The very good in my wanting list, is now, I have Ebrake when I press little the brake pedal and normal brake when fully depressed. Picture provided is when I was modifying it.
In case someone wanting to know why I replaced it. While driving at full speed on the road as I done it frequently, rear wheel nearly locked, then the mower died. Another symptom, he was very hard to push like if the motor was on brake. Found moving controller was now full short circuit at entrance and outside (Why it was so hard to push) and after opening it, I forgotten to try to fill it, all glued inside. A luck, I had 4 LifePo4 batteries, one of them tripped seeing this short circuit and cut power then my 125amps fuse never needed to blow. It's why needed to disconnect and reconnect to later found this moving driver was now short circuit. Since only 260 hrs and 300$ US + shipping to replace it, I decided to try less costly alternative. In my case I choosed to try this 3000 watts https://www.amazon.ca/gp/product/B0..._asin_title_s00?ie=UTF8&psc=1#customerReviews, why You can see the blue controller in the posted image. As before it pull like 25amps at near full capacity, maybe 2000 watts version will be enough? I choose to not take a chance and it's anyway cost way less in my case compared to Ryobi controller one.
But now I must take care to not forgot to put key in off position because now I don't have the buzzer anymore. :D
Where did you find schematic for original controller so you could wire up replacement
In this forum, a post, someone published I will call it one version linking to google share if I remember correctly. But to connect it you don't really need this schematic, what I done is I tested all wire needed (And it's why I can say in my case I didn't get exactly the same color). For info, about motor, it's easy, same color at generic driver, same for hall sensor. In my case, color was not the same for the accelerator for the return signal (To not forget, it's a hall sensor then no resistance, then needed to test resistance on both side of the wire to be sure it's the good wire). For forward reverse, I prefer to use a new switch compared to the original. Now I use a (Normal 120 volt light switch) bolted on steering, then I don't need to remove my hand from steering anymore to go to reverse.
On my own Ryobi 480E, I built too a full electric shovel and it's why I already have a lot more hours on it. The moving driver broke at 260hrs, right now I'm already over 300-330 hrs and with generic driver still work as it was before, exception made buzzer and mower need I click the red light to get mower turning. ;-)
Hi Everyone,
Thanks for all the positive input on this subject.
And thanks to whoever made the service manual available on google.
I have the ‘not moving’ problem. Just I slight jerk forward or backwards and then stops.
I guessed at the drive controller but unfortunately it wasn’t that.
The drive motor is passing the meter test.
But the Hall Sensor is failing its test across yellow green and blue wires, it holding on 5v not switching to 0v as the wheels are turned.
My question, can the hall sensor be replaced or do I have to get a whole new motor?
Thanks in advance.
Wil
Hi Everyone,
Thanks in advance.
Wil
Good question and I'm curious to know the answer since I didn't dismounted this motor. What I can say is dismount this motor and you will have the answer if there is easy access to those hall sensor with this motor. With my Ebikes, the hall sensor are accessible once dismounted, and this Emower use nearly the same drive as the Ebike. :D I'm curious if you share pictures. LOL
Did anyone buy the replacement motor and remove the mower to see if it continues to drive with this motor? Price is up to $376 now and just want to be sure before I buy it?
I bought one, because the hall sensor test I did while I was on the phone with ryobi support failed, it's a small sensor that theoretically can be replaced easily, but they decided you need to replace the motor instead, which when I was trying to figure it out you couldn't buy just the motor, it came with the trans and motor as 1 part, as it turned out it did not help at all.
You are dealing with a substandard company, what I ultimately did was through more money at it, and purchased the drive controller, but had to wait 3 months (basically the whole summer) for it to be restocked. But that fixed it.
Hey if you pm me your email I will send you the Ryobi repair manual. It has how to check using a Multi meter, what everything should read
My friend, if you get this reply and are able to send me the repair manual I would so gratefully appreciate it. I have replaced the motor controller and got reverse and slooow forward. Need to check the speed reducer. Thanks for any help. [email protected]
Hi Guys, I registered specifically so I can reply to this thread.
My RM480e is acting the exact same way as the other Motor Controller issues. But I have an additional issue which could change the ultimate fix. Mine is still under warrantee until august and I do have a place 40 minutes away I can take it.
If I cycle the key multiple times while trying the peddle - it will finally go and I can cut the lawn as usual. I notice that after charging - and the light is solid green - the indicator is often half full - then I plug it back in and the green light flashes and this will now continue to fully charge. Sometimes it still won't for forward but it fails far less often when the indicator is full. So - is the controller malfunctioning, and also, possibly the batteries? They seem like once they are full it will go forever, so I think they are fine. I suspect it may be something else.
Thanks for any help you can offer.
I'm posting here to relay my saga. Bought the RM480EX about 8 years ago. About 6 months ago, batteries gave out. Instead of shelling out for 4 more batteries with an "expected" life span of 5 years, I paid a little more for the LiFePO4 conversion kit from Epoch Batteries. They were great in helping me get it all hooked up. Mowed the yard a few times and it worked like a champ. Then, I started getting problem where it would stop going even though all the lights, beeps, and mower deck worked. Even worse, it deteriorated further where if I was going down a sufficiently steep hill, the motor would essentially let go into a sort of neutral, where the mower would just start careening down the hill and I had to slam on the breaks to get it to stop. I almost tipped over a couple times, pretty scary. Again, after that it wouldn't go forward or backward until I waited a while, then it would go for a bit and do the same thing, and eventually hardly more than 10 feet. It would sometimes lurch just a tiny bit like it was trying, but nothing.
So, following the advice of this thread, I paid $300 for the deck motor controller and installed it. Same problem. Then $140 for the speed control switch. Same problem. At this point I give up. I am getting a gas zero-turn and taking the L. So much for these electric mowers being the future. I'll never buy a Ryobi anything ever again.
I hope I can sell the LiFePO4 battery for a decent amount to try to recover my losses. Also, anyone want to buy a Deck Motor Controller or two?
