2000 Dixie Chopper xw2500 tbox question
mikeeee372
2000 DC XW2500 tbox leaking oil. Can the seal be replaced? If so can it be done from under mower by removing just the pulley. Gears in box are good. Bearing seams to be good but I do not know if the seal is made into the bearing. Any help always appreciated. Thanks Mike
hlw49
No the seal is not made onto the bearing. Yes you can remove the bottom seal with the T-Box still on the mower. The part no is 788099. It is a peerless part. Don't buy it from Dixie Chopper it is $41 and some change. You should be able to get if for less than $20.
mikeeee372
So it is held in with a snap ring? Just remove the snap ring pull the old one out put the new one in correct? Thanks for the info!
hlw49
No the snap ring holds the bearing in not the seal. Nothing holds the seal in but the intererence fit in the T-Box. One thing you should look at, make sure it is the seal that is leaking. There is an o ring on each side of the T-Box where the pumps bolt on. Over time the heating cooling and expansion and contraction can cause the o ring to shrink and cause them to leak. They are part no. 4421221 takes two.
Tiger Small Engine
I am sure you have to remove the gear box, take it apart, and install seal. Lots of work. Put some 00 Cornhead grease in the gear box and keep mowing.
hlw49
Tiger I don't want rain on your parade I work on these things daily have installed many bottom seals in the T-Box. You do not have to take the T-Box off to put the seal in.
Do you drain the oil first? I would think that need be done to keep the oil mess down depending on the bearing is getting oiled. Just thinking about keeping the shop floor clean.
mikeeee372
Is there a trick to getting the old seal out?
I was thinking using a screwdriver and prising it out. Or maybe even a small cutter pliers and cutting one notch through it and pulling it out. Thanks for all the great info! I’ll let you know how it goes later this week!
mikeeee372
Thanks HLW49 for all the info I really appreciate it! Happy Father’s Day to everyone!
hlw49
I take a sharp pin punch and peirce a hole in it then take a dry wall screw and thread it in the hole. Then take a small claw hammer and pull it out. Good luck. Thanks
