ruperthebare
Hi,
I have an older Castel garden r/o with a Kohler Courage 15hp. I have had problems with carb etc (see my other posts) but it is now running quite well, fingers crossed. I thought it was a bit juicy, approx 1 uk gallon per 2.5 hours work, so I weakened the mixture right off. Then under load and uphill it would peter out occasionally. Also at this time I noticed a bubble or more appearing in the petrol tank from the outlet pipe (to carb), so air. I have now riched (opened the jet) the mixture right up and the problem of petering out has largely stopped, just one or two suggestions. The bubble is still appearing in the tank. One of the studs holding the carb on is turning and wont tighten fully, but I would have thought tight enough. Any suggestions/ thoughts?
Regards, Rupert
Regards, Rupert
