Chris_feldk
Can I replace the crankshaft gear? I have worked on tons of Briggs and know you can but this is my first Kohler. Sorry if I sound dumb as I don’t have much experience and I’m only 18.
Sadly no. It would require a complete crankshaft. It might wear in and quiet down. Or it might cause some teeth to break.Can I replace the crankshaft gear? I have worked on tons of Briggs and know you can but this is my first Kohler. Sorry if I sound dumb as I don’t have much experience and I’m only 18.
Well that’s likely why this motor was sold. But I got it for 50$ and the tractor for free. And I don’t think it’s worth it to dump 175 in it for a new crank. So I guess I don’t have much to lose and will just run it the way it is. Or at about half throttle and see if it breaks in And gets better. But as for now I will put the motor back together and on. Thank you.Sadly no. It would require a complete crankshaft. It might wear in and quiet down. Or it might cause some teeth to break.
43526 let me just say I am dumb i was getting ready to rtv and noticed I can wiggle the counterbalance gear like a lot. I know the crankcase cover supports the upper half but it is a lot of play.What is the spec number on this engine?
I believe I just figured it out. So the play in the counter balance is so bad I can see what looks like marks all over the counterbalance shaft. And I can see a mark on the rod cap. So I believe the play is so bad that the rod is smacking the counterbalance. And the knock only appears at higher rpm’s and it gets worse the higher the rpm is. I could try and possibly get a new shaft or maybe try to do something sketchy and clearance it I’m not sure.
